forcefed3.8's
Buckeye Bullet
- May 26, 2002
For some reason my scanmaster 2.1 won't display malfunction codes. I never noticed it before, I have used it for codes on other cars, not my own.
I just installed my stroker motor, GTQ76 turbo, 95lbs injectors, modded ECM. The car would run for about 10 mins, start to stumble really bad, check engine light would flash, coolant temp would show -40, 140, -9, etc, IAC all over. I figured collant temp sensor. Changed that, same thing. I then noticed the rpm are showing 6375 when this happens. Changed ECMs, that problem was solved. I wanted to figure what the light was on for, and the scanmaster doesn't even have the MAL display in it. I did the paper clip in A and B, and the light doesn't flash, the car makes a weird buzzing and clicking sound. When I first started it, it idled down, IAC was in the 20's, idle was in the 900's, etc. It then started to idle at 775 (too low), and IACs were at 120 to 140's. Then it started idleing in the 900's again but IAC's were around 84. I shut it off and restarted it and IACs were in the 30's but the idle was jumping from 925 to 1050. The IAC is newer and worked great on the old engine. My O2 is getting lazy, that might be a problem. I have an Extender Extreme chip, and tried open loop idle with no change. Maybe it is locked using the fuel trim from the lazy O2, causing no change? I have the screen removed from the LS1 sensor, and I had to make crappy adapters for my 4" hose to the sensor, maybe it is too turbulant? I plan on running a 4" MAS, but my GEN 2 needs updating.
I have never ran into weird problems like this. I am running a borrowed ECM, so I need a new one. Who sells modded ECM's? Any insight on the idle problems would be appreciated.
