Feb 5, 2012 #2 J ~JM~ Wrinkled Member Joined Oct 31, 2007 Messages 3,251 I'm betting that its better than the OEM speedo. ~JM~
Feb 5, 2012 #3 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 It's driven off the same cable as the speedo so it should be the same.
Feb 5, 2012 #4 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 so it only reads correct if you run stock tires
Feb 5, 2012 #5 A aminga Chicks Dig the powerbulge Joined Dec 15, 2003 Messages 5,578 SIXBANGR said: so it only reads correct if you run stock tires Click to expand... Or if you've got the right speedo gear for the tires you have
Feb 6, 2012 #6 G GNICETRY Cat&wife post starter Joined May 26, 2001 Messages 2,137 My Scanmaster is 4MPH off due to the 255/60 15" tires in the rear. I believe that Eric at Turbotweak can program that into the chip.
Feb 6, 2012 #7 S SIXBANGR mean old man Joined May 25, 2001 Messages 2,446 GNICETRY said: My Scanmaster is 4MPH off due to the 255/60 15" tires in the rear. I believe that Eric at Turbotweak can program that into the chip. Click to expand... thats the same tire i am using. Is it to fast or slow?
Feb 6, 2012 #8 G GNICETRY Cat&wife post starter Joined May 26, 2001 Messages 2,137 SIXBANGR said: thats the same tire i am using. Is it to fast or slow? Click to expand... 4MPH slower on Scanmaster than in reality. I forgot how I measured the 4MPH difference though. That size tire looks like it was made for our cars, it looks pretty bada$$.
