Scanmaster
blackazz
Not a Gn
TurboBuick.Com Supporter!
Video attached, Can anyone tell me what is wrong with my Scanmaster flip out:
looks like data errors.
check connections, where is it grounded? Is the radiator cooling fan running during the video?
Bob
Double checked connections.
I have it grounded under radio dash.
An yes I think the fan was running, At least when I'm cruising around an I see it happening.
on the drivers side inner fender are 3 relays, 1 large one, and 2 smaller ones. unplug the smaller ones and see if the symptom goes away. (watch the engine temp, these are the fan relays)
Bob
Back in black? The irony
1987 Grand National
Stock turbo ,Red 93 street tune chip, 206/206 comp cam, valve spring upgrade, Melling hv oil pump
37lb injectors, Ls1 maf with translator, Oil filter adapter upgrade
K&N filter
Sitting at home not installed yet:
AlkyControl "Razor" injection with 3 bar map, Hot wire kit, walbor pump upgrade, RJC Racing Airflow Distribution Power Plate
15x9 4.25 bs weld prostars 275/60
15x7 weld prostar
