scanmaster
equalizer442
i think my scanmaster is gone nuts, its stoped recording the highest knock sometimes. today i pulled a 9.0 and when i checked it later it was as if it did not pull any, you know the button on the right.
as for the knock its been increaseing and i cant get rid of it. im running 15 psi now, i was runing 17, and some times i get 15-16 degrees but mostly 8-9. for a while i had it running perfectly with around 1 - 3 degrees on top end. any ideas how i can lower it while keeping my 15psi and running on 93 pump gas?
o yeah i nearly forgot. some times atleast once every 10 mins the o2 volts go to 000 for about 3 mins then comes back to normal. would all this came from a bad ground or am i going to have to get a 02 sensor?
Check your MAF I kept getting 000 on mine and it was a bad maf I also started getting knock after not having any the Maf just went bad.HTH
It is normal for it to read zero when you let off the gas
It also will not record unless you reach a certain TPS voltage, so if you are getting knock at half throttle it will not record.
errrrr how much do the new mafs cost? its got a nearly new lake wood put on by the last owner, maby 6 months old
how would you ll go about eliminateing your knock? im running 40 psi fuel pressure ideling, would jumping it to 45 help?
