blownbuick
- May 24, 2001
SCE 4072 Pro Copper Exhaust Gaskets for Buick V6 w/Champion heads
Thickness: .043"
Material: Copper
SCE introduced the first embossed copper exhaust gaskets in 1995 and they are still the best way to seal a warped or uneven exhaust manifold or header sealing surface. In house design, tooling and manufacture insure superior quality gaskets for the widest array of applications. Whether on your tow vehicle, motor home, hot rod or race car, a properly fitted SCE Pro Copper exhaust gasket will form a permanent trouble free seal.
SCE Pro Copper exhaust gaskets have a unique O-ring seal around the exhaust port for a tight, leakproof seal. Made with solid annealed copper, they help even out heat flow between the head and header flange to minimize warping. They'll conform to rough or damaged surfaces to maintain a good seal and keep header bolts tight.They provide improved sealing and even heat flow for your headers.
Six sets available in sealed factory packaging. $40 per set shipped in the 48 states
Thickness: .043"
Material: Copper
