scot w.
GNSperformance.com
- Feb 19, 2005
Well I was at our local roundtrack supply shop and got to talking about oil and lube and they mentioned that they sell Schaffer Oil. They went on to talk about some of the details of schaffer oils & additives. Schaffer oil 20w/50 racing oil is designed for use with flat tappet cams. I plan on giving this oil a shot this next oil change and see how well it works. If anyone had tried this oil please let us know how well it worked. It's cheaper that Royal Purple and suposed to be just as good if not better.
Here is the link to there site: Schaeffer Oil | Supreme 7000 Synthetic Racing Oil
MATERIAL SAFETY DATA SHEET
Manufacturer: Schaeffer Mfg. Company
Address: 102 Barton Street
Address St. Louis, MO 63104
Emergency Response Number:
314-865-4105 (24-hour emergency
number) or
800-325-9962
SECTION 1 – PRODUCT INFORMATION
Chemical Fami ly: Petroleum Hydrocarbons and Additives Trade Name: #705 Supreme 7000 Synthetic
Plus
Racing Oi l SAE 20W-50
Formula: Proprietary Mixture
SECTION 2 – HAZARDOUS INGREDIENTS
Exposure Limits
TVL PEL
COMPONENTS-CHEMICAL NAMES AND COMMON
NAMES
CAS
Number
Ppm mg/m3 ppm mg/m3
Zinc Alkyldithiophosphate Confidential 0.5-1.5 NE NE
Organomolybdenum complex of organic esters
Specific Chemical Identity Withheld (trade secret)
<1 10 15
Mixture of Distillates,(petroleum), hydrotreated heavy
paraffinic and Distillates,(petroleum) of solvent dewaxed
heavy paraffinic
64742-54-7,
64742-65-0,
64742-88-1
70-72 5 5
Polyalphaolefin Synthetic Base Fluids 68037-01-4 16-20 5 5
Section 3 – PHYSICAL DATA
Boiling Point: >600ÿF/315.5ÿC Specif ic Gravity: .87
Vapor Pressure (mm,
Hg):
<.1 % Volat ile: Not Determined
Vapor Density (Air = 1): Not Determined Evaporation Rate: (=1) Not Determined
Solubi lity in Water: Negligible pH: Not Applicable
Appearance and Odor: Blue green color, petroleum odor.
SECTION 4 - FIRE AND EXPLOSION HAZARD DATA
Flash Point (Method) ÿF/ÿC: 465ÿF/204.56ÿC
C.O.C.
(ASTM D-92)
Flammability Limits UEL & LEL ----Not Determined
Extinguishing Media: Carbon dioxide foam, dry chemical foam, sand, earth, waterfog.
Special Fire Fight ing Procedures: For fires involving this material, do not enter any enclosed or confined space without protective
equipment including self-contained breathing apparatus.
Unusual Fire & Explosion Hazards: Dense black smoke.
SECTION 5 - REACTIVITY HAZARD DATA
STABILITY [X] STABLE [ ]UNSTABLE Hazardous Decomposition [ ] WILL [X] WILL NOT
OCCUR
Conditions to Avoid: High heat, high energy ignition sources
Incompat ibility (Mat. to avoid): Strong oxidizers and reducers.
Hazardous Decomposition Products: Oxides of carbon, sulfur oxides, aldehydes and other products of incomplete combustion.
Conditions to Avoid: None
SECTION 6 - HEALTH HAZARD DATA
Threshold Limit Value and Sources: 5.0/mg/m3 for oil mist. OSHA & ACGIH.
Acute Effects of Overexposure:
Ingest ion: Nausea and Diarrhea.
Eye Contact: Irritation and redness to eyes
Skin Contact : Prolonged and repeated contact with the skin can cause irritation and redness to skin.
Inhalation: Vapors can be given off under high heat conditions excessive breathing of vapors can cause irritation of the
respiratory tract.
CHRONIC EFFECTS OF OVEREXPOSURE: Prolonged or repeated skin contact may cause skin irritation.
Emergency and First Aid Procedures:
Swallowing: If conscious give 2 glasses of water to drink. Do not induce vomiting. Seek medical attention immediately.
Skin: Wash skin thoroughly with soap and water. Launder contaminated clothing. Seek medical attention if irritation
develops.
Inhalation: Remove victim to fresh air. If breathing is labored administer oxygen. If breathing has stopped start artificial
respiration immediately.
Eyes: Flush eyes with clear, cool, clean water for 15 minutes. Seek medical attention immediately
SECTION 7 – SPILL OR LEAK PROCEDURES
Environmental Impact: This material is not expected to present any environmental problems other than those associated with oil
spills. If spilled into a watercourse, call the Coast Guard Toll Free No. 800-424-8802.
Procedures To Be Taken If Material Is Released or Spil led: Absorb spills with absorbent clay or other suitable material. Keep
out of sewers or watercourses. Advise authorities if product has entered courses by diking or impounding.
Waste Disposal Method: Dispose of at an approved waste or disposal site facility in accordance with all applicable federal, state and
local laws and regulations. This product is not considered to be an RCRA hazardous waste.
SECTION 8 – SPECIAL PROTECTION INFORMATION
Respiratory Protection: None required under ordinary conditions of use.
Ventilat ion: Local exhaust to capture vapor or mists if necessary.
Eye Protection: Splash goggles or face shield when eye contact may occur.
Protective Clothing: Oil resistant or chemical resistant gloves. Chemical resistant apron if needed to avoid contaminating
regular clothing.
Date Prepared: 05/14/2008 OF-1049 Rev. (1999)
Scot W.
number) or
800-325-9962
Plus
Exposure Limits
TVL PEL
NAMES
CAS
Number
Ppm mg/m3 ppm mg/m3
<1 10 15
heavy paraffinic
64742-54-7,
64742-65-0,
64742-88-1
70-72 5 5
Vapor Pressure (mm,
Hg):
C.O.C.
(ASTM D-92)
OCCUR
respiratory tract.
develops.
regular clothing.
Scot W.
