SD2 chip Brand new in original packaging
nolanator
@none_more_black
set up to run with my E85 setup using 120lb. injectors. You can alter it to your setup fairly easily.
$300 shipped OBO
Since its SD2 what is different than the 93/ alky version and can it be chamged without sending to eric?
Sent from my VS990 using Tapatalk
From what I understand from reading the .PDF manual, this chip works by way of volumetric efficiency tables. The user could make any adjustments they would like with the given options to adjust the parameters to their liking. So, in short, yes. I believe the changes can be made by the end user.
