TurboTdr3.8
- Jan 15, 2013
Parameter 11 – Cold Start Fuel
This number is a fuel trim with 128 being “the middle” or 0%. Higher than 128 adds fuel.
This adjustment will allow you to add or reduce fuel during the cold start routine, under 130°
F coolant temp. Go as lean as possible without causing the car to stall when dropping it into gear.
My car cranks perfect when cold but till it gets to 130 degree or closed loop it seems to be too rich once it runs a few seconds , will this adj help the rich afr in that area or where only till closed loop kicks in . Can this adj be made while its running or have to cut off and restart ? Mine is at default 128 , I do not like the smell of the richness till my WB kicks in , anybody been here yet
