SignUp Now!We run the engine @ low load, [10-15%] for a few minutes.. Usually 20-30.
Cool down, check plugs, check oil, set valves, if necessary, and it's HAMMER TIME!
Wouldn't be Champ alums, would they?
Have you seen problems with the GN1s?
can have loose valve guides. Have seen some guides fall out of the head under "heavy use".
At 1 point, I think there were postings on the subject.
If the machine work was performed correctly, all that is needed to seat the rings is a GOOD whack of the throttle under load.
After engine build, start the engine and run it for about 15-20 mins. at 2,000 RPM. Check for leaks, knocks, ect. and then shut it down. (This is with a roller cam. Increase RPM to 2,500 and run time to 25 mins with a flat tappet cam) Then drain oil and cut oil filter apart to check for any obvious debris. Then, add new oil and filter (duh!) and start the car and let it warm up. Then put the car in gear and slowly raise RPM untill it shows 4-5 psi boost on the gauge (with the brakes applied, against the converter) and then SLAM the throttle down and hit the rings with 10-18 psi boost. Yes, the tires will break loose. Then drive the car like you stole it. There is NO additional break-in to be performed. There is NO reason to "baby" the car for the first 500+ miles. If the machine work and assembly is correct, the crank will never touch the bearings. The only break in is the rings. They will smoke untill they break in. They only need to loaded aginast the cylinder wall to seat correctly. Watch an engine on a dyno some time. They will smoke untill you load the dyno. Then (if machined/built properly) the rings will seat and stop smoking. Cylinder pressure seats the rings.
