Oct 20, 2011 #1 Z z-ya Member Joined Dec 22, 2007 Messages 42 I'm starting to get ocational second gear starts when cold, seems to go away when warm . This is on a 200 4r behind a ls1 in a 2001 camaro . I'm useing mobil 424 tractor fluid in a century built trans . Any idea what the cause is ? Thanks Mark
Oct 20, 2011 #2 7 77 cruiser Well-Known Member Joined May 24, 2001 Messages 1,357 Minimum line press. too high. Can you check it?
Oct 21, 2011 #3 S SSedan64 JoaTMoN Joined Dec 8, 2007 Messages 1,590 A little Info at bottom of Pg. here >> Extreme Automatics Where winning is easy
Oct 28, 2011 #4 Z z-ya Member Joined Dec 22, 2007 Messages 42 Yes I have a pressure gauge in the car i'm seeing about 105 psi in 4th gear detent . This is at idle . Mark
