SignUp Now!my GN has it in drivers door jamb area , across where the outside mirror is when driver's door closed .![]()
And I assume the cowl tag is missing too.
You're screwed. The frame is the only place left and you're going to have to lift the body and clean all of the crud to see those numbers. And it's only the last 6 digits so its really no help at all. If by chance you do get those numbers post back here and I'll see if I can come up with the rest of the VIN for you. The Regals built in Pontiac MI have a characteristic last 6 digits so I should be able to narrow down the full VIN or at least tell you its a Cutlass or MC frame.
If the car still has the original trans, look on the side of the trans just above the pan. The number is stamped on a pad on the left side. It's pretty small so you will most likely have to clean the pan rail to see it.
Did you look under the trunk lid for the RPO code sticker?![]()
Drivers side for the tranny partial VIN.
I also recently recovered my t type which had been missing for almost 2 yrs. the vin on the dash and all other id tags including the trim plate on the cowl was missing. I got lucky because the car had the original engine and the last 8 numbers of the vin were stamped on it. I was issued a replacement vin for the car by the DMV to rivet in the the door pillar but I guess the value of the car will never be what it should as a re'vin. Is there anyway I can get a replacement vin plate for the dash and the trim plate for the cowl.
