Security Alarm
GNX261
Folks, a few weeks ago my factory security system began to malfunction. More specifically, the dask light stays on or blinks continually whenever the ignition is off. The doors can be unlocked/open and the windows down and the light is on/blinks. It continues to work properly when armed (doors locked and windows up).
I removed the negative terminal from the battery for 15 minutes, but that did not help.
Any help out there? I don't drive the car daily and last week the battery was almost run down after 5 days of parked.
Thanks.:confused:
You need to try to turn the door lock with your key and see if that fixes the problem.
It was fine until I locked it once...
Getting ready to pull the fuses and go see my alarm-installer friend. *hint*
