psycho6cyl
Ponies Are For Lil Girls
- Feb 11, 2005
I have decided to sell my Buick. As much as I love the car it is time for a change. The car is completely driveable and fun to drive. It has been on numerous long mile trips. The car was driven daily for years. More good than bad with the car. A couple dollars and you will have a great street/track car. The car is a true G.N,with 3.42 posi rear. It has Concert sound II. Power windows power locks. With this car you get my collection of extra parts for this car. The car has many upgrades and money was definitely spent in the right places. These are the current mods to the car.
-60lb injectors
-Razors Alky
-Turbo Tweak Alky chip
-cpt61 Ball Bearing Turbo
-PTE Stretched Stock InterCooler
-K&N Air Filter
-3.5 Maf w Translator
-bored .30 w TRW pistons
-crank cut 10/10
--ARP fastnes
-Billet Main Center caps
-Comp Cams 206/206 roller
-Comp roller chain
-comp roller lifters
-T&D 1.55 Roller Rockers
-3"Terry Houstan Down Pipe(internal wastegate)
-New GM fuel sending unit
-New walboro fuel pump
-Vac brakes w s10 rear wheel cylinders
-Hood Mounted fuel pressure guage Boost,temp,oil and volts guage
-New GM front cover
-New timing gears
-Recored (w bigger cores) radiator
-Hi flow water pump
-Caspers Hi-Lo switch
-Scanmaster
-Powerlogger(comes with laptop)
-New ARP longer rear studs
-New rear BF Radial T/A(255-60)tires
--Test pipe
-K motion valave springs
-Cd player w new door and front speakers
-Metco Lower rear trailing arms,stock boxed uppers
-Edelbrock shocks
-Moog front springs
(there maybe more ,but that pretty much sums it up)
The parts that come with it are:
-2 Grand National fenders(pass and driv) decent shape,clean with Turbo inner fender wells
-Innovative (NIB) wideband,just need to be installed
-Energy Suspension Poly urthane (NIB) body bushings
-Brake Lines (NIB)-I forget company off hand
-Pass lower quarter pnel
-tensioner-Pair of tailights
-Headlight bezel
-Brand new slicks M/T on TType rims mounted once
-Extra clean front cover
Being that the cars is old it does need some things. Headliner,Pass floor is soft,needs a windsheild(cracked),winshield molding(the long piece that runs across bottom of glass-its fat-just rusty,doors have rust on them,as well as 1/4 bubbles,hood has some small bubbles on it,and the trunk has too. I repaired the trunk on the inside where the lock is also. The paint is cheked on the fenders,but 20 feet away the car looks great. It will also need a 02 sensor,or worse case scenerio a MAF.Once in a while it does puff smoke on start up but i think thats the pvc sucking oil up. it does have the loud comp lifters.
Like I said the money is there in the car I just have lost interest. The price is negotionable but I also have a bottom. I prefer a pick up because of all the extra parts. If the car is going to be shipped buyer will be responsible for payment for shiping items..
I am asking 6500.00 for car and all of parts... email me buickintheblood@gmail.com Will have more pics later this week..
-60lb injectors
-Razors Alky
-K&N Air Filter
-crank cut 10/10
--ARP fastnes
-Comp roller chain
-New GM front cover
-New timing gears
-Hi flow water pump
-Scanmaster
--Test pipe
-Edelbrock shocks
-Moog front springs
-Headlight bezel
