SEM for GN interior
Red Regal T
Senior Member
I was trying to remember what shade of SEM vinyl paint was good for GN interiors. Saw a list that included the color "graphite" and I thought it sounded familiar. Found this link. You decide which shade of graphite will do the job for you ...
Search
graphite is the 84 color bit i dont know what the 85-87 color is. i know its a lighter color than graphite, and a few shades darker from primer grey
GN interior paint/dye
I have used the SEM Color Coat Presidio in my '87 GN. Very good match. I would not say it is perfect but the car is 20 plus years old and sunlight takes its toll on the trim pieces so I doubt any one's paint is an exact match. This is a "dye" yet I have used it on metal surfaces also without any problem. As usual it is all about prep, prep, and more prep before you spray.
Dean
Well, if the link works that I provided, there are a couple of graphites that might work just fine. I have heard guys complain about the presidio, however, I don't think these colors must be an exact match. As long as it's a grey that is somewhat close, that's good enough for me. After all, in most cases you would be painting a whole panel. I usually make my own just mixing black and white. I mean, who really knows when they look in your car that it isn't the exact original color, :eek: and who would care? :D
For example: previously dark blue painted steering wheel and painted center armrest. Note the factory grey leather Park Avenue seats aren't the same shade as the door panels or the parts I painted. My mix was off. :eek: What's one to do? :(
If you can find an unmolested piece of trim that isn't faded your local paint jobber can always mix SEM interior dye to match.
That's what I always do.
Yeah, I did that on my dark red T. Can't remember what I paid, exactly, but somewhere over $50 a qt with no vaseline included. What a deal. :D
$24/pint and a pint is enough to redo a whole interior so it's really not that bad. How many cans of SEM will it take.
took a piece of trim with me off my t, around 1/4 window panel flipped it over and matched it perfectly sun doesn't fade the back side paid like 25-30 for the pint of sems dye, air brushing after detailed cleaning and prep looked better than new also had a different color ttop panel I had to replace cant tell from new. just prep time and spraying several light coats
int colors
here's what we cam up with
83-84 Lt Sand Grey trim
Med Gray kick panel
Dark Grey dash
Lt Driftwood cloth seats
code color pt #
60 DN Lt sand Grey C8384L
82 CN Med Grey C8447F
42 DN Dark Grey C 8327L
Blackout trim 39143
These color are used 83-87 in various combinations got my body by fisher manual has a detailing section on trim and dash refinishing tech and supplier going to try to scan and post got to get new print install
