You would have to use ALL of the 86-87 pullies, brackets and accessories as well as a/c lines. You would also have to relocate your coil pack as the 86-87 set up uses that space. All of the accessories are mounted on the driver side on the 86-87's. There is nothing on the passenger side since the turbo sits in that area.
It would probably clean up your engine compartment alot. Remember that you might have to install and electric fan since the 86-87's used that as well.
The short list of what you need is:
main aluminum bracket
tensioner
alternator
ps pump with lines and remote reservoir
alternator
water pump pulley
crank pulley and spacer
a/c compressor and clutch
a/c lines
steel front alternator support bracket
steel y shaped alternator rear support bracket
L shaped steel a/c compressor support bracket
