those dont look like cragar superstars , they look like weld prostars
cragar do looks just like the weld only they are different enough to tell apart
key appearance difference is the lug area
weld is all aluminum with a two peice center made from a thin front and back that have a support floating in the middle and must use shank type lug nuts .. very light around 12lbs on the 8"
the cragar superstar although more expensive is chrome plated and is cast aluminum center that uses cone lugs that sit in a recess and it has a steel outer drum ,heavy compared to welds
great price either way
whats the backspace on the 10"rears and the 8"fronts ?
