This is I how do it. Set the cam sensor 25ATDC,then start the car and force the cells where it's idling to whatever number you want. Then check with the timing light. Then add or subract in the crank reference angle.
Example: Set all cells surrounding the green ball to 32*, check timing with light, if it shows 28*, add 4* to the reference angle.
