DailyDrifter
The Slow and the Curious
- Dec 5, 2007
Well here we go, I'm on my other laptop now and looking at some of the things on the software, and I have a couple of questions
1. cam sync-firing order. it says cam sync precedes cylinder 1, and the the firing order is 612345 is this right?
2. Global setup parameters. it had the IPU ignition checked off, but I switched it to Buick DIS ignition. Also crank Ref angle is @ 50.00(BTDC)
3. Fuel calculation parameters. I changed displacement to 233cid it was at 400, #of cylinders changed from 8 to 6, injectors to 72LBS, Fuel Energy Constant is at 1
All these are under View then System configuration. I have not yet hooked it up in the car as i need to relocate the wideband, but want to make sure its going to start up when I do. thanks guys
