- May 24, 2004
ok guys, I was reading a post and one member was telling another about using a hose to listen for exhause leaks, knocks, etc on your motor. I have used that trick forever but relized that a lot of you may not know about it. It got me thinking about tricks we have all leaned over the years that would help each other out so here is another one for you guys.
Ok, have you ever filled up the tranny to full, God I hate that, have to pull the plug, or drop the pan to get it back out! Man that really stinks but here is you something to make in your spare time to keep in your shop on the shelf and it will cost you almost nothing.
First, get you a pickle jar, mayo jar, etc. Something pretty good size with a metal lid on it. Now go to the parts store and get you about 9 foot of some small size vacume hose or fuel line. Make sure you get it small enough to go down the tranny tube but get the thick wall hose so it won't suck together. Drill 2 holes in the lid matching the size of the hose you got. Run one hose thur the lid till it is about 2 inches from the bottom of your jar. Now run the other hose thur the lid about 2 inches. One short , one long. The short one leave it about 3 ft long and the other 5 ft or so. Put a little silicon around the hoses thur the lid so they don't leak and a worm clamp just barely snug on the inside if you want . Put the lid on the jar, run the long hose down into the tranny and hook the short hose up to the motor on a vacume sorce and crank the car up. In just a few seconds it will pull a vacume in the jar and up comes the tranny fluid! Continue untill you get the extra out. Easy enough huh and you can use it forever as long as you don't break the jar lol. Daniel Ray Rednecky but hey, IT WORKS!!!
