Well I started to install the CK Performance shift kit in my valve body today and noticed something very strange. I was checking all the valves to make sure they didnt bind and found 3 springs behind the TV Valve. The manual only shows one. Also when I removed the TV Plunger spring a metal tag fell out that said "shift kit patent number*******". This is very strange. I am guessing it is a Trans go shift kit thing but the valve body has not been drilled like is required in the older kits. Also the TV Plunger spring is very short. You can move the plunger 1/4 inch before the plunger makes contact. Please call me ! I am seeing some springs that are not the correct color they would be if they were stock. I dont want more trans problems again. Please call me at work 011496371475145 or 011496371472064.
Thanks,
Brian
PS
Anyone ever seen this before?
Thanks,
Brian
PS
