0-60n4
- Nov 17, 2003
Shift governor is correct and spring in place. Appears to have the original BQ valve body. Had an art carr shift kit and just installed ck performance shift kit. Did learn the art carr had a too heave spring in the tV valve so it wouldn't work with the CKP kit so changed it out to correct one. Adjusted the TV cable correctly with visual of plunger while pan was off.
at lighit and part throttle the 1-2 occurs but a little late in the rpm range but acceptable. However at WOT it doesn't shift. NOTE: In first WOT is revs to 5200 rpm then falls on it's face. I can let off the throttle and back on then it will shift. Could it be the shift wants to happen at maybe 5400 but the engine wont go there?
I have adjusted the tV cable in and out to the extreme in both directs but still no shift.
Any thoughts or advice?
