Shift Kit Recommendations ?????
ANDYS87
I recently purchased a TransGo shift kit from Summit. I haven't installed it yet. The instructions aren't that great and the video has little to do with the instructions! This damn kit wasn't cheap either....around $130! I think I just paid for production of that video........anyways, I was wondering what people are using out there in their GN's. I am looking for firm, tire chirping shifts. I actually like harsher shifts...as long as I don't break anything. Which kit has the most bang for the buck? Quality, price, GOOD INSTALL DIRECTIONS, etc? I appreciate any help.
That's the kit I have in mine, haven't tried one from CK. If I was going to do it again with the same kit I wouldn't go as big on the hole size for OD not with the 3 frictions in it, hits hard. I'd go a bit bigger for 3rd like .110.
Other than that it does the job.
I too have that kit as well. I think it is ok. I didn't use the little plug they supplied, and the pressure spring wasn;t much more than stock it seemed, so I used a different one. If you read Ck's manual the kit covers pretty much everything CK does, so I would think it is pretty similar.
Make sure you do not follow any of the instructions on that video! Use the paper instructions only.
