imjoesnuffy
I just break stuff!
- Sep 13, 2005
Just got my car running today after having the engine rebuilt. Ran into an issue with the shifter and changing gears.
Went to back it out of the garage and it was in a forward gear.
It's possible it was initially in neutral, I may not have noticed and thought it was in park when I reinstalled the motor and trans.
So I disconnected the shifter cable from the trans. Moved the arm on the side of the transmission all the way forward/up into park. Reconnected the shifter cable moving the shifter into P.
Now the shifter acts like it has too much slack in it??? Too loose to shift the gears. Starting from P I can go to R, N, OD but no further down. Once in OD I can't move all the way back into P. If that makes any sense.
Any way to tell if the shifter cable is broken? I thought maybe I had rebolted the shift cable bracket in the wrong place on the bottom of the pan, but it is where it was before, I can tell from the grime outline where it bolted to the pan.
If I have someone hold the button in on the shifter I can move the gears manually from the below the car and it will move into the corresponding position. The shifter cable feels solid and in one piece. Won't work from above????
Any ideas?
Any ideas?
