- Dec 21, 2001
I don’t have a leak down testerDo the other 2 tests
SignUp Now!I don’t have a leak down testerDo the other 2 tests
Get one or borrow one,or get someone to leak it down for you.I don’t have a leak down tester
Used the CL-SBC-14 kit from mellingIf you used shitass lifters then it could very well be a lifter tick.
Just because it's new, doesn't mean it's good. Was the cam break-in done per "the book"? From 2000 miles away in an online video, it sounds mechanical.Used the CL-SBC-14 kit from melling
Hot oil pressure is 25-28 psi. Cold is 80, cruising is 45-50. I did the cam break in like I’ve seen on here. Ran at 2000-2300 for 20 mins then change the oil. Driving and will change oil again after I’ve reached the 250 mile mark. Sounds like it could also possibly be a flex plate or torque converter noise... I’ve used a mechanics stethoscope and listened all over the engine and trans. I can’t hear any sudden noise or it pronounce itself anywhere.. probably shouldn’t have but I took the pcv out and put it onto the metal valley pan and couldn’t hear and loud knocking or clicking. Just really loud under the car. Goes away under acceleration and cruising above 2000 rpmJust because it's new, doesn't mean it's good. Was the cam break-in done per "the book"? From 2000 miles away in an online video, it sounds mechanical.
What's the hot oil pressure?
A flex plate would likely tick all the time. Warm the car up, and unbolt the converter and push it back into the trans. That will tell you if it's the converter. Did you measure pushrod length?But, as it warms up and gets to temp, there is a ticking sound that starts.
Yes, and I put them back in the same lifter it came off. Also measured the lifters and they were the same as the originalsA flex plate would likely tick all the time. Warm the car up, and unbolt the converter and push it back into the trans. That will tell you if it's the converter. Did you measure pushrod length?
What lifter preload target and what's the actual?Yes, and I put them back in the same lifter it came off. Also measured the lifters and they were the same as the originals
I was told it’s a drop in kit... I’ve never built and engine before.. just put it together. it preloaded probably a 1/4 - 3/8 inch but I honestly have no clue...What lifter preload target and what's the actual?
Understand. We all started somewhere.I was told it’s a drop in kit... I’ve never built and engine before.. just put it together. it preloaded probably a 1/4 - 3/8 inch but I honestly have no clue...
If you are talking lash, all the rockers have about .025-.030 lash between the valve stem and the rocker tip.Understand. We all started somewhere.
I would revisit the lifter preload and VERIFY its' correct, regardless of any other findings. YouTube will be your friend.
Hydraulic lifters should not have lash. Lash is air gap. They should have preload which is the opposite of air gap. With a cylinder at tdc compression the pushrods should be snug, no clearance. If they jingle that's the noise. Could be only one doing it. TIf you are talking lash, all the rockers have about .025-.030 lash between the valve stem and the rocker tip.
Should not have air gap. Lash is air gap. Preload is the opposite of lash.If you are talking lash, all the rockers have about .025-.030 lash between the valve stem and the rocker tip.
Yes. There was metal after the break in but thats to be expected. Cut it again after 100 miles and no metal!Have you cut the oil filter open ?
