Farrell5.0
- Feb 6, 2017
When I got my car, it had a ratchet shifter and hacked up shifter plate. I wanted to go back to the stock appearance so I got a stock shifter from a member on here, new handle and applique overlay.
Anyways, I'm new to messing with automatics, so I'm clueless as to how the shifter cable is supposed to be set up. I got the stock shifter in and ran the cable underneath and got it in the bracket with the clip in place. Now, at this point the end that connects to the transmission is a little over an inch away.
I figure I'll move the bracket to the next set of holes on the oil pan....too far forward. Where it looks like it would work, one hole lines up, and another is blocked. I imagine that if this bracket were factory, everything would like up just right, or am I missing something here?
Also, the pin with the cotter pin that the end of the cable slides onto to connect the transmission, has threads on one side and doesn't fit through the hole where it connects to the transmission.
I feel like I dumbass because I don't know what to call any of these parts lol I'll provide pictures as I'm assuming this is hard to follow. Bottom line is, nothing seems to line up and I don't know what I'm doing.
(Disregard oily mess)
Sent from my SM-N950U using Tapatalk
