Shifts into 4th gear @ 76MPH - 2500RPM
Are all the other shifts OK and on time ?Have you tried adj the tv cable ?I had to add a small washer behind the tv vavle spring (inside the trans) to get my trans to shift properly. the tv valve would not extend all the way otherwise .
Mark
I will run the car again, to check all the other shift points, I think shifting into 4th is a pain because i have to get up to around 80mph.
never checked the TV valve, is there a proper way of setting it?
thanks
