There wasnt any free slop in it, but there was alot of movement that was kept under tension by the wave spring. The shaft would move like 1/8 inch up and down. Someone had already shimmed it before with the wrong shim (I.D. too big), but it was the same thickness as the Delco shims I have. I pulled that one out, and ended up with 2 of the right shims. Now there is only about .020" of movement in it, but its under so much spring pressure from that wave spring, thats its hard to move. I didnt have any issues lining up the oil pump drive shaft. The biggest PITA was getting the lock screw back in. My engine is way quieter now. All that noise that was coming from my oil pump area...well most of it, is gone. Now I have a bunch of other noises I have to track down. There is some loud buzzing like rattle that happens at about 2000rpm when Im driving. Doesnt happen in Park.
First off, you dont need a voltmeter or special tool to set the cam sensor. GM designed it with alignment marks that line up when you have the motor at 25* ATDC. This is a little trick that Lou Czarnota showed me.
Another problem was, that there is lot of rotational slop in the cam sensor ring. Neither drive gear is worn out, so thats not it. I think its just a basic alignment issue when the hole was bored on the block. Removing the up and down movement with shims reduces this rotational play some. I can see why advancing the cam sensor helps alot of people overcome stumbling problems. When the engine is shut off, the window in the ring isnt in the same place as it is when things are more dynamic, and the engine is running....because of all this rotational slop Im assuming.
Bottom line, my engine doesnt sound like its about to blow up anymore. I cant believe what a simple cam sensor can do.
