Jan 8, 2004 #1 C camino70 Member Joined Jun 11, 2001 Messages 361 When installing a new starter, how do you tell when and how many shims are required? TIA. Ron
Jan 8, 2004 #2 T turbosam6 My cars suck Joined Jul 24, 2001 Messages 3,356 Haven't seen a buick v6 need the starter shimmed before. At least on the few I've worked on.
Jan 8, 2004 #3 R Reaper Pit Bitch Joined May 24, 2001 Messages 2,681 i had to shim my starter. wwhen you get the stater you normally get a little round gauge. place that between the flywheel and the starter gear if its less or more then it needs to be shimmed. Dathan
Jan 8, 2004 #4 C camino70 Member Joined Jun 11, 2001 Messages 361 I did not receive a round gauge test the distance, is there another way? Thanks.
Jan 8, 2004 #5 R Red Regal T Senior Member Joined May 24, 2001 Messages 19,243 Are you having a problem? Most times shims are not needed.
Jan 8, 2004 #6 C camino70 Member Joined Jun 11, 2001 Messages 361 No problems, just wanted to make sure there wasn't anything I should be doing... I don't want to cause a premature death.
