Short Block
tta1240
CAMEL TOE
before i get my short block built i wanted to see what was out there already built.
i am looking for a built 109 short block with a steel crank.
let me know what you have.
thanks jim
I have a 109 short block. 4 billet mains and girdle. Je pistons and pins, Stock rods with arp bolts and cast crank. Motor has been 6.40's in the 1/8 mile. Federal mogual bearings. TQ plate honed. Build\t by RayMac Racing engines (Ray Little). RayMac Racing Engines Home Page
I know you said you wanted a steel crank. The only reason for puling the motor was I'm building a SBC v8 with a 88mm turbo.
$2k firm.
I will get the pics posted, just been buisy with work and other peoples car projects and mine. I will pull it out of the bag on sunday and take pics. Sorry for the delay.
shortblock
I have a shortblock being built right now. I have to abort because of moving and buying house.. here goes
109 block, bored .040, torque plate honed, decked .003" each side
stock crank w/rolled fillets 10/10
2 dot rods
2 center billet main caps
wiseco forged pistons/rings/pins will make compression w/champion irons 8.9-1
comp cams roller cam kit
218/212
roller lifters,
dual roller timing chain
adj. cam button
arp main studs
arp rod bolts
arp cam plate bolts
durabond cam bearings, clevite 77 rod and mains
new freeze plugs
painted any color you want
crank, pistons, rods and cam all computer balanced with the damper and flexplate
all work done at polarek engines in valparaiso, indiana
new high volume timing cover made for the longer gears, comes with the gears, oil pressure booster plate, filter adapter, adjustable oil pressure kit(you can adjust off idle oil pressure by turning a screw)
rjc deep sump oil pan
complete engine gasket kit by felpro
never ran , should be done this week 3750 shipped to your door
I also have a fresh set of champion irons and t/d rockers and comp pushrods
add 1500 for those
