Should any sealant tape be used on the nozzle fitting on Razors kit?
2QUIK6
Turbo Milk Jug displacmnt
I just installed the nozzle in the uppie for Razors kit and was wondering if any teflon tape should be applied to the nozzle threads or the braided line threads into the 90 degree fitting?
There is not any sealing surface in these connections, just pipe threaded is all.
Brass on brass seals itself However; I did not put any tape in the up pipe nozzle. I have had not one problem.
HTH
Bo
Cool, thanks, just wondering since there was teflon tape on the assembled filter components that can with the kit and they are all brass.
Not needed.. but you can use a smidget of paste or tape if you like.
HTH
