GNguy said:
I have heard of the ECM actually catching on fire
I've run the stock ecm til destruction in a controlled manner with a low-Z load, and never approached getting that hot. I've also taken a Syclone to destruction with low-Z injectors, and while the PCB got crispy, again, it didn't catch fire. The highest case temp., I've ever seen was 150dF, and that was in a destructive test.
If one was to run a stock ecm until driver failure, the first signs of it failing would be popping, or going lean at WOT. It's when the PW get long, and the *off* periods short, that the drivers get hot.
And I've driven 300 miles at a time with low Z injectors without any driver failures.
Having an ecm fail in traffic, isn't pretty, so the safe choice is just doing it right, and having the drivers changed, to properly handle the load of the low Z injectors. Last I heard, Bailey Eng was the only one with the proper drivers for making the conversion. There are two types of Peak and Hold drivers, and the proper one has been getting hard to find.
