I checked through the voltages on the crank and cam sensor wires and I have NO voltage going to the crank sensor, is it supposed to have power going to it? I check the crank wires at the coil pack module and there is no power there either. I even went back to the ecm and checked the B5 purple/white crank reference hi wire and there is no power there either? Should these wires not have any power?
