spooledstang
- Oct 1, 2003
My alky setup has been working awesome for about a month, but now it has a very bad leak at the pressure switch. I took it apart, and the seal between the pressure switch and the pump looks like the culprit, it is tearing apart. I've been running M10 at 75psi with 100% methanol. Not sure what I should do now, if I put it back together it may fail again. Any suggestions? All I can think of is that the cycling of the pump wore out the seal.
