Single to dual nozzle
dank GN
BlackArts Automotive (661)993-8277
I just converted to a dual nozzle setup. Is there any changes I should do to the initial knob on the controller ?
To give you an idea I am running 125 to 126 mph I ran the single on 8 and now I have a dual and have it on just over 4 30lbs on the single and 25lbs on the dual i had a stock longblock on the 30lbs and now running 25 lbs with ported irons now Hope that helps
I just converted to a dual nozzle setup. Is there any changes I should do to the initial knob on the controller ? View attachment 216790
Looks like the Initial should have been higher to begin with and someone also moved the turn on up. So the kit was tamed down when it had a single. Should have moved Initial UP before going to a twin nozzle.. there was more juice left on the single.
Julio should the initial be around 12 to 1 o'clock for a max effort single?
yes sir.. the higher the initial.. the more aggressive the kit is.
Thanks for that info Julio.......since I'm running a max effort single nozzle in to the 9's ...........I have got another pump that I'm gonna swap out and have you rebuild it. It's been since June of 2012 since I installed it .
Well get it down here and i'll be more than happy to go through it.. need you running top notch in the event a race with JD happens :whistle:
Mmmmmmm well I thought you would have a bigger challenge than just throwing JDs name out. ;)
I need to send mine too. Just put my new one on and took off a good pump. Just needs refreshing.
