HighMileage
Albany,NY
- Jul 24, 2010
I keep having these skip/miss issues. This time it's at very light throttle and deceleration. On decel, an occasional *pop* is heard from the exhaust.
Once past light throttle pressure,the engine pulls smoothly and strongly. WOT peels me eyelids back! Idle is *ok*.
Cruising along with the TCC engaged in 3rd is when it is really noticeable. Like a bucking bull.
Other skip/surge issues have been solved by:
1)New coil pack.
2)Check/replace vacuum lines. There are no leaks now.
3)The TPS is set perfectly with no dead spots.
4)New,correct PCV.
5)New,correct plugs gapped at .030 per TurboBuRick.
6)Fuel Press 43 with line on,55 with line off.
Note: When I replaced the old fuel filter a few weeks ago,there was a piece of cellophane stuck in the outlet of the old filter.
Any input appreciated.
Steve. '87 GN. Mostly stock. Powerlogger. <--still reading about how to correctly use that.
1)New coil pack.
4)New,correct PCV.
