Slick TTA Wheel
rollie
TurboBuick.Com Supporter!
Will a 28-11.5-16 fit without rubbing on the stock wheel?
Thanks Brad
I'm running these, with barely any issues. Specs are in the pics.
I have those on the car now I was curious if the 11.5 wide Hoosier slick would fit with the stock wheel.
Should fit. Metric cross reference is 292/52/r16. There's quite a few conversion calculators online.
Great info I was curious if the 295 would fit stock rim dvernst those are mickey ets ?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Yep. In that size they only have the e.t. street radial 2, but they've been awesome. Had to make sure the axle was perfectly centered by adjusting the panhard bar, and had to massage the inside of the wheel wells a tiny bit with a big hammer. Other than that no rubbing. Pretty consistent 1.49 60' times too. They hook great at the track. Launch at 20psi. Was getting 1.48 60' times with a 26 x 10.5 tire, but was a little inconsistent, and anything over 10 psi they would spin.
That's great to hear congrats on that serious 60 foot my car came with the typical 255 R16 wrapped around GTA I see a lot go to the 275 but I wanted to look at and 295 plus the extra roll out of the taller Tire I'm due for some now so you already know but this info here what I'm ordering the massaging is no problem I'm from the big hammer baseball bat fender rolling Era myself
