Slick & Wheel Size For The Track??
PIC'S OF THE NEW WHEELS & TIRES
Thanks Guy's 4 the help. This is what a came up with :biggrin:
i'm running a 15x10 inch rim with a 275 60 15 micky.. i also run a 28 by 10.5 micky full slick at 9psi.. my frame IS NOT notched nor is my fender lip rolled it fits up under there with room to spare..
RUQWKNF27 said:
"UNDERBOOST" are those 15x10's on the rear??
Yes.. They are WELD Aluma Star 3ps 15x10 4bs 275/60/15 M/T street in the back. I'm going to put my slicks on them because the space is awsome. I also bought 10x15 w/ 5bs for the street and 1/2'' spacer's. I just want them in the fender well a bit more. What you see in the pic 4bs w/ 3/4'' of space from the frame rail w/ M/T's the fit is perfect at 25psi. :biggrin:
What size tire are you running up front an do you have any pics of the car from the rear??
Front Tires M/T Sportsman 26x7.50R15
Is this what you're looking for? I could take more just let me know.
Brent
How about one a lil closer so as to see the tires!!!! Do you think the 275/60 is wider looking on the 15x10?? I have those same tires on a 15x8.5 amn I am wondering what they will look like when I decide which 15x10 I am going with!!!
Would a 15x10 w/ 4" BS and 28x11.5s fit under without notchin the frame? Just wondering cause I can get a sweet deal on some ET Streets
I had the 275/55/15 on my stock rims and they looked bigger. But there the same. The side wall is almost flat with the 10''. I hope these pic's help I suck with the camera. :tongue:
I have plenty of space w/ the 4''bs and I was told to run these slicks. I'm not sure about the 11.5 M/T ET streets I do know You Need Air Bags. w/ 275/60/15 I run 5psi on the street to keep my outer unrolled fenders lookin perdy :biggrin: .
Yes those are nice pics!! thanks.. That ghetto 300C across the street ain't too shabby either...Next time you take some pics seeif you can borrow your neighbors wheels an put them on the GN :rolleyes: :eek:
LOL They are for sale $$$$ :biggrin:
Underboost said:
Hi Guy's
What size Rim, and Slick can run with the stock rear suspension?
I will be buying 2 Air Bags of course :)
I have M/T Drag Radials 275/50/15's on the stock rear wheels for the street and they rub a lil not bad only on hard turns.
How big can I go with new Rims & Slicks :confused:
I'm going to be buying these. :biggrin:
http://www.centerlinewheels.com/wheels_detail.php?mw_id=13&sw_id=72
Please Help Guys!
I would like it to sit like this pic bellow
Thank You Brent
P.S If you guy's could post some pic's that would be great. :biggrin:
Well since that is my car in the pic you posted I can tell you how to get it to sit like that:
15x10 rim w 4.5" bs (mine are 5" bs with 3/8" spacer)
28x10 slick (if you use a 275/60/15 you can use a 5" bs rim with no spacer and a little frame massaging)
Lower car in rear 1.5 inches
Roll fender lip as much as possible
26" tall front tires
Set pinon angle after lowering
Ill post a few more pics later. Glad you like the way it sits. Everyone tells me the same thing. :D
Here is a rear 3/4 shot of the nicest sitting GN in chi-town..... :D
Here is another....
With the ATR sway bar it was consistent mid 1.3's on slicks (best of a 1.299). High 1.4's on 275/60 MT drag radials. I do not have any new times with the HR bar but I expect them to be just as good on slicks and better with DR's.
I don't get it I launch w/slicks 11x28 goodyears at 23psi off the trans brake and I get a 1.6 with 3.5 psi in the bags. I launch at 18psi 1.5 with no air in the bags. :confused:
Dunno, every car is different. Buy adjustable parts (UCA's, shocks, etc) and play with pinion angle, shock settings, tire pressure, air bag pressure, etc. Make ONE change, make a pass. Did it help or hurt? Make ONE more change and make another pass. Spending TIME on my car was worth more than any single part I have ever purchased.
Yep! I hear you. Thanks for your input.
