bird
- Feb 20, 2003
Guys i found a great deal on some center line auo drags 8.5 with 5" backspacing just for the track. With my m/t 28x9 et drags they rub the inside frame on both sides. I installed a 1/2" billet spacer, with the gm 3" studs and i do have the aluminum drums. Is this to much of a load on the studs? are we talkin danger here, and has anyone run a simular set up with any problems? shorts should be in the 1.5 range i assume.....
