77 cruiser
- May 24, 2001
This trans has a TransGo kit in it which I know a lot of you don`t like very much, but I think all is well other than the slight bind on the 2-3 shift. It has the no. 2 chk. ball removed and the alum. slug in place & the 3rd acumm. hole enlarged to .110 as per intructions. BTW the bind appeared after I instaled a GN servo it had what I think was the next siize smaller. OK what should I do?
A---drill a hole in the alum. if so what size to start with
B---enlarge the hole that is now .110 or
C--none of the above & I`m open for suggestions
I hope I described the parts right if I didn`t someone will correct me.
thanks
Jim
thanks
Jim
