Evans Ward
Love those LC2/ Y56 cars!
- May 24, 2001
I've just noticed a slight whining noise coming from trans/ torque converter area that sounds like when the power steering pump is low on fluid only with car in gear. Will not do it in either park or neutral. Noticable to the ear over the motor noise. Trans is newly rebuilt with only about 1500 miles on it and it shifts firm with no noticable problems or slippage. Torque converter was replaced then too and it's a CK Performance Pro-Torque D5 remanned 2800 stall unit. I checked trans fluid and it looks great with no discoloration (Amsoil synth universal ATF), level good also at alittle above the full mark. No leakage underneath car. Is the whining sound a bearing going out in the TC? Wonder if I should drain and drop trans pan to take a look. Could it be cavitation or filter backing out? Might look just to see for that. From the reading I've done, most said TC suspect if it doesn't whine when in park or neutral too. Easy miles on this combo, no track use. Should I not use or drive the car at this point as I want to save this trans!? Thanks for any help guys!
