Well, Just got back from the track a few hours ago.  This is how it went:
Best 1/4 time: 14.033 at 102.7
Best 1/8 time: 9.1 at 81.5
Best 60 ft: 2.489
02s between 740-800
A/F around 165
This is after I put in my new TE44 and 009 injectors. My octane had to be the worst ever because I started out with about 1/8 tank of pump gas and added 100 octane up to 1/2 tank. My tires are pretty bad, but I dont think there is ANY way I should be going this SLOW! My fastest run was at 19 PSI, and the knock gradually increases from around 3 to 14 at the end of the run. I only got knock in 3 and 4th gears. Could it be false? should I replace my sensor? I tried running with an idle fuel press line off of 55 PSI and still got the same knock. Is there something I am missing that is making my car THIS SLOW?!?!?
Best 60 ft: 2.489
02s between 740-800
A/F around 165
