Slow blikers/turn signals
Ryan
CEO/Founder Nakslist.com
Both side blink very slow. The right is much slower.
Take the bulbs out and clean the corrosion in the sockets. The problem is too much resistance in the circuit, and if there is too much resistance its going to take electricity longer to reach the breaker and flash.
Thanks for the response. Did not think anyone would respond. Do you have any recommendations on how to clean the socket?
I would get new bulbs, or first try getting a small wire brush or pick and scrape the contacts.
Also, check the grounds....
U can use electronic component cleaner,[SAFE for plastics on the label!], and a stainless brush. After cleaning, some di-electric grease is a good idea.
Had the exact same problem. It wasnt a case of dirty contacts. I simply replaced the flashers under the dash and it fixed the problem. I think there is one for each side.
