converted to LED
J-B Racing
Forced Induction
Can someone help me here. I replaced all the stock lights with LED. I have tried a few LED Flasher Units and the turn signals won't work.
Is their a specific one that will work, or I just wasted my time!!
Thanks for any help
Joe
I used two of these. Make sure you have them grounded.
CEC Industries EF32RLNP Flasher​
One should be for signals. One for the hazards of if I remember correctly.
But if ya go to LED, & don’t change the hazard flasher, it won’t work correctly.
I did the same as you Joe.
Had to change both relays to electronic LED flashers . Still had issues. Seems there needs to be a certain amount of resistance for them to work properly . The fix for me was to replace one of my front marker lamp bulbs back to incandescent .
Problem solved, they worked perfectly afterwards
Good to know. If it happens I will know what to do. Great info
besides the no load relay on the right side of steering column under dash ..if you put leds in the corner lamps (194 bulb socket) the leds need to be special to allow flow in both directions , normal LED is a diode and wont work
in that case, I will trouble shoot one step at a time.
Thank you so much for the information I get from you guys.
