WarWagon
Caustic Cacophony
- Mar 10, 2007
June wasn't bad or great on my Buick. It has been running great on the street but as soon as I get it on stage to do work at the local 1/8th mile drags, issues show up.
It was very hot to be out in the sun beating on the car and it had started building excess pressure in the cooling system but continued to run alright. Had boost problems all day that also led to over fueling and falling on its face. This same engine had gone through testing of two failed waste gate diaphragms and has seen several hits with boost nearly 40 psi and no fuel to cover it. Last week I got a new waste gate diaphragm and installed it in a different waste gate and went for a test drive of boost control and both or at least one Fel-Pro 9441pt head gasket has let go from all this. As time allows I'll swap in 2 new much better head gaskets and continue testing.
