Tim Barnum
- Oct 15, 2001
I just aquired a 89 TTA with a 60-1 turbo, 218/218 cam, ported heads, big neck intercooler, 40lb injectors. The car still has a stock converter and spools very slow. Should I install the stock turbo to run high 11's or do I need to get a converter and stick with the 60-1 turbo? All I want for know is 11's . Thanks Tim
. Thanks Tim
			 . Thanks Tim
. Thanks Tim . I took it out just now and I can spool it to 5lbs boost with the foot brake on the street. So that may do the trick at the track with the cutout open.
