smc alcohol injection
84conversion
does anyone know were i can find a wire diagram for a smc alky kit. dont know were the 4 wire go on the controler
I'd like to see it also. There's been other posts asking for this but so far no ones come up with one.
There should be instructions in that stack of paperwork that went with your car.
I will check again and if I have them I will post up for everyone. Cork did you run denatured or meth in the car when you had it ?
Denatured, but if I would have used a alot methanol is far less expensive.
older non progressive with the large controller
from the bottom of the controller up as your looking at the control face the wires are black, red, blue, white.
Use a test light and with the 12v and ground hooked to the unit already, hit the spray button and figure which connector is sending 12v to the the pump. Then with your test light still grounded, probe each of the other three connectors. One will light your 'spray' light - blue on mine, one will trigger the low alky light and the other is the ground to the pump. Hopefully this works with the prog. systems too.
