Smog Pumps Setup: Where is the best place to measure vacumn from?
karolko
As the title says i was wondering if some of you guys could shed some light on this topic and what you have done.
The only reason i am doing this is so i can datalog the vacumn pump and make sure it is running correctly and not pulling too much vacumn,
I am of the opinion that if your engine is sealed, then you can pull vacumn from anywhere and you will get the same readings.
As of right now, i have tapped the passenger side valve cover and ran a -3AN fitting and line to the MAP sensor. Will this work, or should i be reading it from the bottom of the intake valley pan?
Adrian
..............As of right now, i have tapped the passenger side valve cover and ran a -3AN fitting and line to the MAP sensor. Will this work, or should i be reading it from the bottom of the intake valley pan?.....................Adrian
The VC should work ok as long as there is no breather, and it is sealed. :cool:
We usually plug the PCV hole with a threaded plug which has a hose barb to connect the line to the 1 Bar MAP sensor.
With a "real" vacuum pump there should be a regulator at the pump to adjust vac between 10-14" vac. :)
thanks Nick, in my readings i have read alot of people still leave the PCV valve in...
I don't think the smog pump will be capable of reaching 10-14" pull. I am honestly only doing this for the oil leak thing.
Adrian
