Mike70gtx said:
I'm starting to notice quite a bit of smoke, escpecially after I drive a while and come to a stop light. I also noticed smoke coming from under the hood around the turbo housing. Could the turbo be bad? Is it also possible that the valve guides are bad, didn't notice smoke on start up.
It's a stock turbo and was only supposed to have a few hundred miles on it. Yeah, right>
From the read, it sounds like the smoking started after the turbo exchange?
Valve guides may be bad but they do not "suddenly" go bad.
Check for oil
after the TB on the inlet side of the turbo.
It should be dry.
Remove the down pipe and see if it is moist.
Check for exhause leaks under the hood.
Also, verify your PCV.
You can diconnect it, take a 10 mile drive and see if the smoke diminishes.
As far as smoke under the hood ......
Are the bolts on the turbo tight and no leakage? Look for leaks at the exhaust elbow at the turbo.
Also verify the doughnut seal and uppipe for corrosion under the mesh (If you have the OEM up pipe)
This is not "residual oil" from installtion is it?
That should keep you busy for about 4 hours. Ask me how I know
Edit:
OOOOPS, hope you are talking about the 84 and not your 87
