SignUp Now!Yes, the filler is to close to the intake and the oil can backup if poured to quick and will get into the intake. Smokes for about 5 minutes, made this mistake before!That doesn't sound right ^. Did thay from new?
Then you should get smoke at cruising speed with about 40psi of oil pressure going 60mph or higher. Its probably your rings sealing after they get hot and not your turbo seal gone.In my case... it smokes only when the engine is cold, mostly at idle.
When the engine is warm, no smoke..
Plugs are clean so that oil must be coming from the turbo....
Once the oil pressure lowers, the smoke is gone.
The turbo oil seal replacement... is something diy or it needs some special tools?
Who replaced your turbo seals for youProblem solved... turbo seals were blown by the oil pressure
