SignUp Now!obrut said:the seals on the intake valves seem ok but there are none on the exhaust valves. So if the guides are to lose the oil will just run down the valves and blow out of the exhaust. Maybe i have a combination of bad guides and to much oil pressure?
Exactly! :biggrin:lazaris said:Its unlikely for the engine to smoke while its running because of a bad exhaust guide. It may puff smoke on a start up after sitting for a while or overnight due to a worn guide. However while its running there is pressure in the exh port which would tend to push the oil away from the combustion chamber, unlike the intake guide which has a vacuum pulling on it.
Sure: BUT- the stem passes through the exhaust runner on it's way into the chamber. It doesn't take much sneaking into the runner to make a bunch of smoke. It wouldn't show up on the plugs either. The flow in the runner would draw the oil, just like flow in the throat of a carb pulling gasoline from a jet.lazaris said:Its unlikely for the engine to smoke while its running because of a bad exhaust guide. It may puff smoke on a start up after sitting for a while or overnight due to a worn guide. However while its running there is pressure in the exh port which would tend to push the oil away from the combustion chamber, unlike the intake guide which has a vacuum pulling on it.
IMHO ........ Since the engineers at GM did not see the need for them (as stated in previous threads), and there are many engines out there that do not smoke without the seals installed. This was the main reason I did not install exhaust stem seals on my heads. The seals will get rid of the smoke in this area, but, there is no data how long the guides / valves last with them.Jerryl said:FWIW;
Exhaust valves (as you know) do not have seals. Some have had good luck, but I would advice against installing them. Same with bronze guides - They do not last. Cast iron guides are proven and have a similar expansion rate as the stem. ............
obrut said:i also wanted to add that i had the turbo rebuilt twice and installed the pvc catch can and still had a smoking problem. I will be pulling the heads this week, can anyone recommed a good machine shop in IL?
ya i did the same thing, two turbos, two intake gaskets and i tried the pvc catch can. I really think this is my problem, it obvious that oil is running down the guide and that would explain the smoke on start up.
